It takes some creativity, but you can do it with second fob, or physical key.I haven't tried this yet but afaik you can't lock the CX-5 from the outside without having a key fob/transponder with you
Ok, take your word for it. Not going to try it myself as no point for meIt takes some creativity, but you can do it with second fob, or physical key.
I'm all for limitations for users. But why? That's my question.They've set some limitations on the system. One is you need to be in range and have the key fob/transponder with you.
I guess it does. But curiosity feeds the cat...Probably for the majority of owners, it works fine
My keys spend much of thier life here. Your method is going to screw me over frequently.![]()
This is a normal functioning. You press the button while having a key, and the hutch opens. It doesn't open when you don't have a key while pressing the button. What seems to be a problem then? How else would you open the hatch while having a key to test what you're looking for?Related question. 2018 Touring. Walk away feature is off, did factory reset. No matter how I lock the car the lift gate will open if I have the key on me. All the doors will not open. The key has to be out of range for the lift gate to lock, as close as on the hood. If I approach the car with key, doors stay locked, but I can open the lift gate. I want the lift gate to test locked when I have the key on me.
Same hereMy keys stay in my pocket.
My car doesn*t always automatically lock after I walk away from the vehicle. It seems if I stay in the car for a short time after I turn off the engine then when I leave it doesn*t lock. Does anyone have any advice to make sure that it will lock every time? I did ask the dealer and he said maybe the battery of my key fob needs changing, but I did that and it doesn*t make any difference. Thank you.
This Walk-Away Locking feature on CX-5 is not guaranteed working thats for sure. Mine works about 80%~90% of the time, which makes me slowing down and paying attention to the beeps while Im walking away. If yours works only 50% of the time you should bring it up to your dealers attention.
