Took it in for a windshield chip repair but the windshield cracked along the way. So, new windshield is needed.
Do you have windscreen replacement on your insurance policy (uhm)
I do so all is good. I left the house and it was still a chip from what I could see. During the 30-40 minute drive it cracked about 4 inches right in front of the camera.
I also stopped by the dealer and picked up the touch up paint. I*ll do that after the new windshield is in.
Did they switch? Because the cabin filters came as the charcoal filters from the factory. Many said they looked dirty when it was actually just the charcoal.The original filter is white, all the dark stuff is really dirt.
	paris, there is enough material left on the disk, after they have turned it?
That would be great news. I could turn it myself, when the time comes.
Sorry to hear that. Don*t those little bumps just piss you off the most?!
First time ever having a reversing/parking lot accident in my 10 years of driving tbh. It definitely did piss me off. Hahaha.
The worst was looking in the camera after catching the seat straggler and seeing a stang about "impact imminent" away from my car and not being able to stop in time, hahaha. Hadn't actually hit it yet when I saw it in the camera. :/
Yes. When I bought them in they guy said it would probably take only one cut as there was no scarring on the rotors at all. They just needed truing. In my experience, you can generally turn rotors 2-3 times (assuming there is no major damage) and still be within spec. I assume they checked the final result to be sure and I had no reason to question them about it as it was such a minor issue to begin with. In 50+ years of doing my own brake work, I've never replaced a rotor unless it had gone metal-to-metal. I've always had them turned and never had any issues.
From my experience you always need new brake rotors when the pads need to be replaced on most European vehicles like my VW's and BMW as the brake rotors seem to be softer than pads and the rotors wouldn't have enough minimum thickness usually stamped on the disc. But the brake rotors on most Japanese vehicles such as my Honda CR-V the brake rotors can be turned 3~4 times and they still meet the minimum thickness requirement.I had issues with disc turning, from some shops.
After that, I started turning my own discs on the lathe, with a dial indicator.
But it's been a while, since I did that. I thought, that lately everybody just replaces the disc with pad together. I assumed that the discs these days, are thinner and they are not machinable, like in the past.
That is good news. Thanks
