That*s a bit like saying they should take an AWD in the snow and check it before delivery. It should work and probably does. Set the aircon to something mid range and don*t disable any part of it, just leave it on auto. It won*t work until the engine is warm. To activate it, you have to tell it that you want it to work rather than keep running when say you turn out of a junction. To do that, press the brake firmly. As long as all 3 icons are lit when driving like I asked you to check and as far as I know didn*t, it will work. The steering wheel has to be within *10 minutes* of the straight ahead position and you must not load it. If you load it in the slightest it won*t stop and if you load it in the slightest when stopped, it will start again. If in doubt, let go of the wheel or completely relax your grip of it. Remember, all 3 icons with a blue halo, no load on the steering and a firm press of the brake, it WILL work.
