Vibration when car is cold (cx-5 2017)
laf
Cx-5 GS Awd
Anyone experiencing vibrations when car as been sitting for several hours.
Every morning when I put the car in reverse and hold the brakes, the car is shaking.
It goes away when its warm.
And its not the cold. Its been around 2-3 celsius in the morning.
Yes I am aware of the of the issue about the engine mounts below -17 celsius.
But now its happening at around 0.
Could be a related issue or maybe just an issue with yours.
You do know that from a cold start, the engine does run at higher revs for a period in order for it to warm up. Could be yours is running longer because of 0 and hence you notice more vibrations
Did you get an answer to your issues? We were having a similar issue on our 2016.5 and had it at the dealer yesterday....problem solved, let me know
They are still saying its related to the engine mounts.
must be unrelated to our issues as they were not only cold start vibrations...we actually had a couple of stalls but the dealer fixed the issue which was due to the computer, and fuel lines. Flash seemed to fix our problem.
Mine does that too. Started when it was just cold, but has since began to do it at higher temperatures, around 0 degrees, as well.
I knew I wasnt crazy then.
I am certain the car wasnt vibrating at around 0 degrees.
Strange behavior.
