2017~2025 Do 2017 GT headlights have HID lights?
Yeah we have to go outside "manually" push the outside mirror housing to fold one by one, no switch, no auto folding; and that's the highest trim CX-5!
Well to be fair I can pull both mirrors toward me without exiting the vehicle.
I supposed it just needs be done with just enough force so as not to damage the mechanism.
Really? BTW I've seen a few AUS CX-5 DRLs now, the inner parkers are brighter than the halos. Not even sure if the halos are actually on because if you look and compare with the CX-9 halos, the CX-9 halos are clearly fully illuminated.
This is correct. The halos are dimmer than the parkers on the CX-5. The CX-9 one (only on Azami) just has the halos lit and nothing else.
It's like they have reverted to when the CX-5 was first released where the DRLs were substitute of the inner high beam lamps and then the mid-life update changed to signature halos. Hopefully in their mid-life update of the current model, they will change the DRLs to how the CX-9 ones are. ie. fully lit halos only.
Quite possibly. It is still currently bright enough as a whole DRL (halo & parker) though
No, they are designed to do that. Hitting the side of the garage is enough to damage them...as I found out on my last car. But not regular use.
