Post Pictures of Your CX-5 Mods, Upgrades and Accessories!
little storage box,now has a purpose
CX5 cubby.webpA little something I did to make that useless cutout more useful,also convenient location for a flashlight.
Finally got my rice professionally painted/body matched. Had it since october and now I have to wait to install it.
How did you mount these? where did you get them from? I have a set but it looks like there is no place to mount them.
I sell them. Mounted them under the door panel. You gotta drill a hole for them. Unfortunately I totaled my CX-7 a few weeks ago. Got a caddy SRX now and already started hooking it up[emoji16]
Sent from my iPhone using Tapatalk
love it . wish i could do more then im doing but i want to keep the room for other things so im only doing one sub :-( . are they 15s ? what watts you pushing to them ?
12" had about 2,000 watts total rms but I totaled the CX-7 got a caddy SRX now
Mine with Vossen wheels 19" 285mm wide at the back, 255mm front
how are they better?
Because they articulate in two positions vs 1. So when the car is lowered, the ball and stud can sit more vertical vs at an angle. Especially when you are turning, and going over bumps, the hub is less subject to movement caused directly by the spring/Lower control arm movement ( even on a oem height car).
Imagine if the ball stud at the end of that arm was one piece; it would be under a lot of tension, because it would not be able to bend to sit at the same position as pictured, or it would be at Mac deflection always, so under load, it would have no platly. This causes extra wear, and feedback in the steering.
good to know, I thought it (stock) was a ball joint type end and moved in any direction
Nice thread. Can't wait to get mine too. Has anyone turned the non-automatic powered windows to full auto on all 4? The one I'll be getting has only auto on the driver's side.
Mine came with 4 auto and illuminated switches. Never had it on any car before.
Really? Post a pic if you would, I would like to see it. I wonder if it's just the switch or if motors need to be replaced in the doors. Maybe the Mazda6 switch would fit
