New owner (maybe?) + Recall Notice!?
I missed that one today. Hopefully it is a trivial fix that can be rolled out quickly.
Hi all,
I was scheduled to pick up my new Silver 2016 CX-5 AWD GT in about 2 hours. I was super stoked until I saw this:
http://consumerist.com/2016/02/01/mazda-recalls-stop-sales-of-cx-5-vehicles-over-fuel-leak-concerns/
This sounds fishy to me.
The 2013 CX-5 is reportedly NOT included in the recall and yet I am not aware of any changes to the fuel system between 2013 and 2014. The 2013 has a non-return valve mounted inside the fuel tank that prevents fuel from flowing back out the filler neck. I assume the 2014-2016 use the same valve.
Mazda USA indicates a recall for the Mazda3. Possbile error in reporting?
http://www.mazdausa.com/MusaWeb/displayRecallOwners.action
I punched in my VIN on our 2013 and the only recall showing is Mazda Recall #: 8915K for PCM reprogramming. Looks Like I need to get that done.
That page says as of 1/31... maybe it will be updated tomorrow? as the older Mazda 3 recall is only thing showing up right now....
Looks the same to me.
[2013 Schematic]
[2015 Schematic]
No idea what part of fuel line this is about but was just looking under mine and the area where #21 and #11 connect is on a curve near a frame piece that I could conceivably see being crushed in a square on rear collision. Just wild speculation though.
EDIT: It me closer to where #15 is located
Who knows... a hitch may even mitigate the issue
But if they didn't change the frame between 2013-2014 then the 2013's would be recalled as well.
Your diagrams above don't depict the fuel cut-off valve because it is part of the fuel tank. I wonder if the fuel tanks have different part #'s (2013 vs. 2014+).
Some erroneous info in this one as the CX-5's tank is not in the very back.
"The recall appears to echo safety concerns that led to a recall for millions of older Jeep Liberty and Grand Cherokee vehicles. Safety advocates claim the rear-mounted tanks are prone to rupture in rear-end collisions, either from tank puncture or separation of the filler tube. Fiat Chrysler Automobiles disputed the allegations but nonetheless agreed to recall the suspect vehicles.
http://www.leftlanenews.com/mazda-recalls-cx-5-warns-of-fuel-leakage-in-rear-end-crashes-90893.html
Just left my dealership empty handed. They couldn't give me my car because of the recall. I have to wait a couple of more days....
It could be just an oversight so far as we have very limited info.
Fuel tank PN: KD3342110C
[2013]
[2014]
Could be a line change implemented between the two model years, same part just assembled differently. Or it may be one of those "inspect and fix if needed" recalls. The 3 had something like that where some tank components were installed incorrectly and some weren't during part of a spring production run.
Bummer! This is one of the first cx-5 recalls that I'm aware of.
