OK, here's my issue. I have a GT(non-Tech) with halogen high and low beam. I have swapped the black plastic trim surrounding my fog light with an aftermarket surround containing LED lights. Now, since these LED's are on all the time(although dimmed when in high beam or fog light mode) these result in my halogen DRL/highbeams appearing even more yellow. So, my hope is to upgrade my DRL/highbeam 9005 bulbs to something that gives off at least the same lumens and beam distance, BUT, be whiter as well, to complement the LED's around my fog lights.
From what I have read on other CX-5 threads as well as here, LED replacements(at the moment) for my DRL/highbeam unfortunately won't give me the proper beam spread or distance, but just look whiter, and HID's aren't a suitable option for DRL/highbeam applications in a non-tech version.
I have read that the Sylvania ZXE's are supposed to be that brand's whitest halogen bulb, but some reviewers suggest that their lifespan is REALLY poor. This seems odd since the basic Sylvania halogen bulb is the OEM bulb in my 2014 CX-5. Something about it's higher energy demands burning the filament out sooner that the basic model. Others caution ever getting a bulb that is tinted blue as this causes a blue tint to the light(which I definitely DON'T want) but also decreases the light/lumen output.
A previous post here mentioned a Philips 9011 bulb as a higher lumen replacement( with a bit of tab trimming) for the 9005 , but is it whiter than the OEM bulb? Is this bulb a good replacement for the non-Tech version or meant only for the DRL light of the Tech model?
I am open to any and all suggestions!!
