CheeseHelmet
a self-lubricating material that has oil particals suspended in the metal
That's pretty cool
The image is from http://corksport.com if the OP is interested.
Part number is B001-46-062, cost me $3.85 each from a Mazda dealer near Montreal.
EDIT: I forgot to include the part number for the bolt, it's B001-46-134 (the one under the shifter). The other bolt (near the transaxle) is GA2A-46-133.
This is what you'd have to order:
- 1x B001-46-134 - Bolt, under shifter
- 1x GA2A-46-133 - Bolt, near transaxle
- 4x B001-46-062 - Bushing
Just wanted to add my two cents here: We had the exact same symptoms with a 2008 Mazda 3, and there is very little on Google about Mazda 3's with this issue. Our local mechanic was unable to find and solve the problem .. twice! Well, this being the US, chances are that our local shop has never seen a manual transmission before, so we went and found a transmission specialist instead.
Now, I know little about cars, but I'll describe what they said as best I can recall it. Before examining the car, they figured it might be a bushing. Turns out, however, that the real problem was that the transmission cables were in direct contact with (resting on) the catalytic converter. The mechanic replaced the transmission cables and made sure to suspend them away from the converter, and now all is good. He showed us the old cable - it had holes and was black from heat contact. No wonder the stick was such a pain before.
