I use the crc white lithium grease spray. they also have silicone lubricant. I get them from walmart because they are a lot cheaper.
What product is suggested for applying to the little rubber cover that is over the outside door handle lock/unlock button? Wore mine off the 2008 and had to replace it. Seems some lube or protectorate might have preserved it.
Does anyone know the Mazda part number or can recommend a lubricant for door and trunk hinges ?
I'm getting squeaks from the hinges. Thanks in advance.
I don't think I have what you're talking about....not on my 2008, but if it's UV damage that 'killed' yours, you could also try "303 Aerospace Protectant" - the stuff works very well. I use it a lot on my boat, and also for my trailer tires, tire covers - just about anything rubbery/plastic that sits in the sun.
