You're putting stock wheels on so you got lots a room. It's gonna look a lot better. If you did go to a wheel with similar specs as the RX-8 wheels 18x8 @ 50mm you definitely won't need the 3mm on the front as they sit pretty much flush as it is. You'll like the look of the stockers kicked out a bit I'm sure!
hibern8r
What size are those tires?
I have a 2010 5 Touring with OEM 17" rims. I believe they are 6.5" wide. I am running slightly larger tires at 215/50R17. I have a bent rim and am thinking about buying a set of OEM wheels off of craigslist to replace mine. Right now I have my eye on a set of 10-spoke CX-7 or MX-5 wheels. Both of these wheels seem to be 17x7 instead of 17x6.5. I have no idea on offsets. Question 1) Will my 215/50R17 tires fit on a 7" wide wheel and is there any problem with that? Question 2) For mazda, is the bolt pattern and offset from the cx7 and mx5 similar for me to use on my 5?
Thanks!
Do you know the part number or cost for an euro OEM front Mazda 5 license plate holder? I want it for bumper protection
Do you know the part number or cost for an euro OEM front Mazda 5 license plate holder? I want it for bumper protection![]()
