Hi,
these information are very useful - Thanks. But I am not a Pro and have the following question:
I am driving a Grand Touring (tire - 225/55R19 99V / wheel - 19 x 7J), means standard.
Now I want to have something more 'sportive' like 245er and I do not want to change the wheel size.
1st question: does another tire size fit on my stock wheel ?
2nd question: do I need to have any changes on the body of the car?
3rd question: the Mazda dealer said that with all changes on my wheels I will have problems with my TPMS and/or the speedometer. Is that correct?
Thank you for some answer
K
Will a 245 60 18 tire work? If not what would be a good size tire. I am mounting them on some 2011 Mazdaspeed 3 wheels.
There is some really good info on this thread, thanks.
Does anyone know if the wheels on a 2016 Grand Touring CX-5 are still only 7 inches wide? I was hoping it grew a little wider so I can put on wider tires. Based on the information on this thread, I suppose the widest I can go is 245/50/19.
I can't say about the MY 16 wheels, but I can say that a 7" wide wheel is in spec for a 255/50R19. How wide did you want to go?
Trust the tire manufacturers - They say it'll fit, it'll fit.
Would a 235/55/19 fit CX-5 Grand Touring?
Yes. It'll lower the speedometer reading a touch, but it's nothing to lose sleep over.
Thanks for the info. I never strayed from the manufacturing recommendations with my past vehicles. However my CX-5 2015 Grand Touring is begging for a wider tire. I am saving for nicer rims, but need new tires now. ( still have the originals from factory/Mazda ) I would love any advice on what size tire, brand, tread or style is good. I work for a utility company as a outside facilities technician, ( means I can't use weather as an excuse for missing work ) and have a cumulative 83mls travelAll models use a 5 x 114.3 mm (5 x 4.5") hub bolt pattern. Offsets in the range of 35 - 50 mm should fit - you don't normally see wide wheels with high offsets that result in big backspacing. The CX-5 uses the Mazda-standard 67.1 mm center bore diameter.
Sport/Touring:
Stock tire - P225/65R17 100H
Stock wheel - 17 x 7J
Safe -1 tire fitments and suitable wheel width for tire:
215/70R16 - 5.5-7.0"
225/70R16 - 6.0-7.5"
235/70R16 - 6.0-8.0"
Safe +0 tire fitments (all listed sizes will mount on a 7" wide wheel):
215/70R17
235/60R17
235/65R17
255/60R17
Safe +1 tire fitments and suitable wheel width for tire:
225/60R18 - 6.0-8.0"
235/55R18 - 6.5-8.5"
235/60R18 - 6.5-8.5"
245/55R18 - 7.0-8.5"
255/55R18 - 7.0-9.0"
Safe +2 tire fitments and suitable wheel width for tire:
225/55R19 - 6.0-8.0" (1)
235/50R19 - 6.5-8.5"
235/55R19 - 6.5-8.5"
245/50R19 - 7.0-8.5" (1)
255/45R19 - 8.0-9.5" (1)
255/50R19 - 7.0-9.0"
265/50R19 - 7.5-9.5" (2)
Safe +3 tire fitments and suitable wheel width for tire:
235/45R20 - 7.5-9.0"
245/40R20 - 8.0-9.5"
245/45R20 - 7.5-9.0"
255/40R20 - 8.5-10.0"
255/45R20 - 8.0-9.5"
265/40R20 - 9.0-10.5"
265/45R20 - 8.5-10.0" (1, 2)
Grand Touring:
Stock tire - 225/55R19 99V
Stock wheel - 19 x 7J
Safe -3 tire fitments and suitable wheel width for tire:
Safe -2 tire fitments and suitable wheel width for tire:
215/70R17 - 6.5-7.5"
225/65R17 - 6.0-8.0"
235/60R17 - 6.5-8.5"
235/65R17 - 6.5-8.5"
255/60R17 - 7.0-9.0"
Safe +0 tire fitments (unless wheel mounting width is noted, tire will fit stock wheel)
235/50R19
235/55R19
245/50R19
255/50R19
Note 1: Pirelli doesn't seem to think that the rest of the tire industry's standards for suitable wheel mounting width apply to them. There are quite a few Pirelli tires that have oddball width ranges compared to other tires of that size. I've noted where I ran across these in compiling this list, and marked sizes for which Pirelli has at least one offering with a different recommended mounting width. There are undoubtedly more, but this is just what I've run across so far.
Note 2: These sizes are somewhat questionable, but Continental's Tire Selector indicates that they're suitable fitments for a CX-5. They certainly meet the load rating requirement for the vehicle, but I'd keep an eye out for rubbing if anybody wants to try them.
As for bigger sizes - If anybody can find a 21" wheel that will fit the CX-5, I'll be happy to compile suitable tire sizes. Until that happens, I'm not bothering with it. Anybody who wants to put 22" wheels on their CX-5 can do their own homework - the load ratings on the tires are marginal at best, and the wheels are ridiculously heavy. I strongly recommend against it.
Sport/Touring:
215/70R17
235/60R17
235/65R17
255/60R17
Grand Touring:
235/50R19
235/55R19
245/50R19
255/50R19
