Hi all
picked up my first Mazda about 3 months back for a song and dance. Its a 5 speed 03 Protege5 base, originally a southern car from Virginia (with original window stickers, PDI report, and checklists in the owners manual to boot, as well as the original owners registration card). Purchased it with just under 118k miles, and currently has 122350 on it. So far I have to say I love this car! Gas mileage is phenomenal (seeing about 34 around town and 38 hwy), the 2.0l is a great motor, and it handles really well. Very impressed!
Picked it up for $750 due to some minor dents and a small tear in the front bumper.cover from a deer hit in central PA. Insurance company screwed the last owners and totalled it due to being more than 40% of the value of the car, so their loss was my gain ^-^ so far I've replaced the drivers side mirror, drained and filled the transmission with 75w90 valvoline synthetic oil (grey bottle rated for limited slip differentials as well as open diff), changed oil and filter, and both rear calipers due to an e brake malfunction.
The car came with a timing kit, water pump, and new v belts, as well as brand new hankook tires. So, with that said, here's my issues that I need some help with
I've been lurking the forum looking for info on how to install the parts that came with the car. The timing belt is out of my comfort zone, although the write up I found here was excellent (thanks for that btw!). I tried tackling the v belts, as my alternator belt was squealing in wet weather. I did manage to tighten it up and get it to stop however I would like to change the belts soon. Te problem is, I cannot get the pinch nut on the power steering tensioner to break loose (although the rest of the bolts will move freely). It's also rounded over. What I am wondering is, can I replace that nut if I can break it free with a 14mm easy out? Does anyone know the size of the nut and the thread pattern (course or fine?) And can I get a new one from the parts house or hardware store (or.is it a dealer only part?)?
The other issue I have is that the clutch chatters in 1-3, mostly when the car is cold. I'm suspecting the flywheel is warped or has hot spots.in it.
I think the clutch is going out as well, since it engages about 1/4" off the floor (possibly enslave cylinder as well) and I get the occasional grinding when I try putting it in reverse (first is also a bit sticky when I downshift). At the mileage on the car and suspecting its the original factory clutch/flywheel, I'm planning to do a new one before winter. I'd like to upgrade to something a bit more heavy duty and from the threads I've read.it seems the stage 1 exedy with the fidanza flywheel is the way to go. I do plan to mod a bit down the road, nothing heavy duty. This car is a daily driver and will get suspension mods for autocross occasionally. I'd honestly like to go with a spec 2+ clutch kit and the fidanza. Can anyone provide me.part numbers for.the exedy stage 1, spec stage 2/2+ and the fidanza flywheel for the base model 03 P5? None of the threads I've read here have the part numbers listed, and.everything I've found online is for the mazdaspeed p5. Are they the same part numbers as the msp5? How do the clutch parts I'm looking at feel for every day driving? I'm not looking to have to stand on the clutch pedal but I do want a nice firm feel with parts that will hold up to abuse (2nd gear pulls, etc)...Plans with clutch also include new slave cylinder and braided line.
Are there ss braided brake.line kits available for our cars? What would be the best option out there for.the budget minded modder? How about coilover options on a budget? Are there poly motor mounts/trans mounts/shifter bushings available?
The last.issue I'm concerned about is oil use. When I bought the car I didn't.notice any blue smoke on startup. I ran seafoam thru the intake.and crankcase before I changed the oil to Castrol edge titanium extended (gold bottle) 5w30 with a purolator filter (made in USA by Baldwin, same internal media as the Bosch distance plus at half the price). Shortly after I noticed I get the blue smoke.on startup and I lose a quart about every 1500 miles (I run 7500 mile.change intervals). From what I've read this burning oil problem is.a.common issue, but what causes it? The compression is good across the board, only thing I can think of is the oil weight is too low and/or the valve guides are worn... I did read.something about the oil passages.in the rings are too small and.get clogged, is this.correct?
Any info or tips.is greatly appreciated! Thanks guys and gals!
