flatlander937
- '11 Mazda2 Sport
Got the oil and filter changed(Pennzoil Platinum 0w20 and Purolator PureOne filter), and changed the trans fluid with Redline MTL. Also used a magnetic drain plug for the engine oil... to make me feel happy on the inside.
Seems to shift a bit smoother now, if its like my Mazda3 was, then shifting will improve even more over the next few hundred miles.
If my son takes a nap I'll maybe sneak out to the garage and try to get some camber plate progress made.
edit: Also when I had the battery out for access to the trans fill plug, I weighed it. The battery in it is 32.6lbs... lots of weight reduction to be had there. Will probably go with some cheap ATV/Motorcycle battery for the auto-x season. I have some gift cards to <s>hell</s> Walmart that would take care of that. Will just have to make up an adapter or buy some to normal SAE battery posts.
