Midnight_P5
- 2003 Mazda Protege5
First things first:
I'm fairly new to this forum, and so far it has been very welcoming, and I've learned a bunch about Pro5's and Mazdas in general.
I bought my 2003 Protege5 (I think it's a 2003.5, as it has the spare tire subwoofer) almost 2 weeks ago. It's in pretty decent shape for my intended purpose of using it as a secondary car. It's got 158,4xx miles on it, so it's a little long in the tooth, but it seems to run well. Or at least I assume it's running well, I've never owned a Mazda before. For all I know, it could be running like poo.
The previous owner warned me of a couple codes the ECU was throwing (evident by the CEL).
Well, I just got back from Autozone, and this thing threw 5 codes. Guy at the counter said I was the winner for today, as I had the most codes.
Here's the list:
Luckily, these have solutions that I've found on the board here:
I'm going to be placing my order in at RockAuto ASAP, so I can get this fixed this weekend.
If anyone could offer any advice or tips or any kind of help at all, it would be greatly appreciated.
How I felt at Autozone:
Here's the list:
- P0037 - "O2 sensor heater circuit low - bank 1 sensor 2"
- P0421 - "Warm up catalyst system (RH) efficiency below threshold"
- P0300 - "Random cylinder misfire detected"
- P0442 - "EVAP control system leak detected - small leak"
- P0660 - "IMCC actuator circuit malfunction"
- To my understanding, these are the 4-wire, heated O2 sensors. Since the "heater circuit" is reading poorly, I'm going to assume the O2 sensor is bad. Since this is "sensor 2", I guess that means it's the downstream sensor? Am I correct in reading into this? Or is the P0421 code causing this as well?
- This code can be thrown because of the P0300. I'll fix that first. Cat is probably bad, but I'm not spending money on it.
- I need to change the coils, wires, and plugs. RockAuto for parts, me for labor. Done deal.
- Could this be the gas cap? That's what I'm going to change first. Hopefully, that'll work. Does anyone know what else could cause this code?
- From what I've come across, this is the EGR valve. It probably needs cleaned/replaced, but a bunch of the things I've read said this code can be set off by the P0300 code if it goes untreated.
