Installing v3 triton led switchbacks
03.5 MSP
I need help locating the positive headlight wire because this is supposedly the wire that dims the turn signals when the headlights are turned on. Thank you. I have a mazdaspeed protege
Low beam or high beam? There are only three wires for the headlight bulb, low beam pos, high beam pos and ground.
prtege actually uses a ground switched circuit. the headlights are positive, low ground, and high ground
