Mototr Mounts that work with Inserts? MAP and Mass Airflow sensor
2005 Mazda SP23
Hi,
Anyone have a link for Motor mounts that can accept the inserts? Some after markets won't work.
Also I need the MAP and Mass airflow sensors if anyone has them for sale.
Does flashing the ECU work?
Thanks
Paul
MAF and mass air flow are the same thing, do you mean inlet air temperature?
Why are you flashing the edu?
Are conversation is spread between a couple for emails.
Yes to your question. I need both. How is $50 for the sensors?
BTW, do you use the inserts on your motor mounts
Yes, inserts in the motor mounts.
As for the front motor mount, the DEA one doesn't accept it. It's shaped a bit thicker than the OEM front motor mount.
Yeah I have a thicker front mount brand new but it won't accept the insert.
I need to replace my trans mount. The AWR doesn't work.
Any low cost sources?
Not that I know of. You could try to get an old one from a junkyard or ask around for a used OEM one.
