These indirect TPMS can be impacted by road surface. Uneven or different material (on side concrete, on side blacktop) can trigger them. It's happened to me many times on different cars that use these indirect systems.
On related note, I set the instrument cluster tire pressure reminder warning to 30days, but at every 15 days it will warn me to check. Kind of annoying sine it is set to 30.
The rear passenger tire has been down 1-2 psi every week or so. The other tires stayed at the same psi. It tripped of the TPMS warning a few weeks ago & I've been checking it every few days. It didn't loose air when it was warmer out but since its been cooling off bc of fall, only that tire is 1-2 less than others & I keep filling it.
Probably not a tight seal as I didn't find any nails or punctures in the tread.
Would that be covered under the bumper to bumper 36k mile warranty?
I guess I can take it to a tire shop.
