scoobs
Stupid question...did you notice any gains after installing the corksport intake or was this purely for a cleaner look under the hood?
Exactly what I just did yesterday. Be interested in how you fabricate the mounting brackets. Hopeful you can post some pictures when you're finished
I will post in here and in my build threadI got to find the hardware but it will be a 1000time better than the large ugly oem box
It seems like the stock airbox allows for air passage over the ECU to cool it, or does the air flow down a different path? If the ECU was designed to be cooled by the intake air, I'm assuming people will start seeing issues as the ECU is subjected to much larger temperature fluctuations especially during winter.
Well.... got a price for the alu front plate to be machined, then got a price for the rear box to be fabricated...
But then a mate posted this on the facebook group https://www.facebook.com/photo.php?fbid=688829411211528&set=pcb.926754014018026&type=1&theater
So you take the air box top off
Using a sharp knife work you way along the plastic weld join
You could fit this with the badge, or cut it down....
So you end up with this....
Now where to put it....
Shaun.......
