Mazdas247 Mazda of the Month | April
Antoine
Administrator
Congratulations to Maleskimp3!
Vote Now for May!
Nate Maleski
2001 MP3
Engine
Paulter Rods
Wiseco Pistons 83.5
ACL Race rod Bearings
PTE 6262
Cometic headgasket
Cometic exhaust gasket
Cleveite Main Bearings
*Block casting cleanup
AWR oil pan
*Port and polished head
*Torque Plate
Super tech dual springs
Super tech Ti retainers
Super tech +1mm Intake Valves
Super tech +1mm exhaust Valves
*Valve shims
SRS cam gears
*Cam sensor pickup
ARP cam tower bolts
ARP cam gear bolts
ARP valve cover bolts
*Water pump Impeller
*Fuel Rail
*Dual PumpIn tank pump holder
x2 Jay Racing PT342 Fuel Pumps
Aeromotive FPR
Golan Fuel Filter
Earls and Vibrant AN Fittings
*Exhaust Manifold
*Full exhaust
*WG dump tube
Tial MVS waste gate
*One wire alternator brackets
Chrome One wire alternator
*Custom boots with MSD wires
NGK plugs
ACT 6puck sprung
Fidanza fly wheel
MSP axles
*Thermal Spacers
*Intake Manifold
ARP intake studs
Vibrant Silicone Couplers
Vibrant T-bolt clamps
*All intake pipes
Tial Q BOV
Green intake filter
Carbon velocity stack
Greddy catch can system with E vac
Jay Racing Vac Block
Holley 75mm Mustang TB
Eat Sleep Race Inter cooler
Modified Crash bumper to fit
Corksport Radiator
Spal Slim fan
Greddy Coolant overflow tank
*Coolant line relocation block
AWR complete engine mount kit
Powder coated almost everything I could think of to powder
Electronics
AEM EMS4
AEM Smart Coils
AEM wideband
AEM oil pressure gauge
AEM true boost
Autometer Tach
Autometer shift light
*Push button start
*Replacement main relay board
Rear ABS sensors for launch control
Dry Cell Battery
Interior
Sparco Evo 2
*Sparco seat mount
Sparco FIA Harness
Momo E brake handle
Momo RACE steering wheel
NRG steering wheel adapter
NRG steering wheel quick detach
*Carbon Laptop stand
CR3 dead man pedal
3 pillar pod
Switch panel for fans, fuel pump, ign, etc...
*5 Point Roll Bar
*Customized rear seats that still fold down with Roll bar.
*Weighted shift knob
*Re worked Short shifter and ball bearing linkage
Exterior
VIS Carbon Hood
Carbon trunk
Carbon Grille
HID lights
Jay Head wastegate dump
Aeroquip hood pins
Vortex generator from STI
ARP fender bolts
CR3 ADP
CR3 radiator mounts
3.5 MSP rear lip
JayRacing Stickers +6 hp
Suspension / Wheels
M&H Slicks 23 1/2"
15" Rota slipstreams
Bridgestone Potenza
Kazera wheels
Yellow Speed Coilovers
Ladder Brace
V brace
Lower tie bar
Megan Racing trailing arms
Progress 21mm rear sway bar
*Sway Bar relocation Brackets
*Rear sub frame mount (CR3)
*Aluminum Lateral arms
*Titanium long bolts for lateral arms
*Front sway bar end links
*Rear sway bar end links
EBC Brakes
Drilled and Slotted Rotors
Anything with "*" are things I've made at JayRacing​
Thank you Antonie for put on this contest every month and to all that participated and voted.
Special thanks to IMSA for the awesome prize for this month!
Wow! Nice car! 1/4 E.T./M.P.H.?
Thanks!, best so far was 12.4 @117.8 last year.
That engine bay is amazing! what intake manifold are you running?
Never mind I see that you made it! Whoa, ever think about making another one and selling it? hit me up!
