All parts are best offer, so just shoot me a PM and we'll go from there. Not looking to make a ton of money, just want these parts gone.
1. JL Audio 8W3v2-D2 subwoofer
2. Stock LX A-pillars
3. P5/MSP open style cupholder *SOLD*
4. P5 cluster surround bezel *SOLD*
5. P5/MSP Lower steering column cover
6. P5 Steering wheel back cover *SOLD*
7. MP3/MSP 3rd brake delete cover *SOLD*
8. P5 seat belt cover *SOLD*
9. MP3/MSP rear license plate light
10. MP3/MSP wiper stalk
11. Vibrant 3" midpipe gasket *SOLD*
12. OEM P5 midpipe gasket
13. J-pipe heat shield
14. Protege5 rear hatch badge set - *SOLD*
15. P5 upper and lower radiator hoses
16. P5 brake booster line
17. Prosport boost sender module - no gauge
18. OEM ECU pins
19. P5 EGR valve w/ solenoid
20. BBY SPDT 30 Amp relays w/ harness *SOLD*
21. OEM keyfob - FCC ID KPU41704 *SOLD*
22. MP3/MSP Cluster Surround Bezel - with alarm LED cutout *SOLD*
1. JL Audio 8W3v2-D2 subwoofer - Dual 2 Ohm Voice coils, but one coil is blown. This sub fits perfectly inside the stock MSP enclosure. You can wire it up to run off just the one coil, but it won't sound as good as it's supposed to.
2. Stock A-pillars - These are NOT P5/MSP color, they're a darker color. I think they came out of an LX?
5. P5/MSP Lower steering column cover - perfect condition
10. MP3/MSP Sedan wiper stalk
12. OEM P5 midpipe gasket - got from OnlineMazdaParts
13. J-pipe heat shield - a little rusty but overall good
15. P5 upper and lower radiator hoses - upper hose was cut for Prosport water temp adapter
16. P5 brake booster line - was cut for a vacuum block
17. Prosport boost sender module - don't have the gauge anymore, not sure where it went
18. OEM ECU pins - you might need one of these to wire in a VTCS solenoid into a stock MP3 harness
19. P5 EGR valve w/ solenoid - one screw is broken but valve works fine
18. OEM ECU pins
