At least you got another Mazda and didn't become a traitor like I did!
Mazda feels like home. Its hard to overcome that. All the buttons are right where I expect them.
Bruce, we have other MS6 owners in our Facebook Mazda group.
What better time to start than now?Okay but I don't do Facebook.
Well... MSM is going bye bye at the end of the month (if all works out). I will be Mazda-less for the first time since 2007.
hey, where is spring?![]()
Came home with the CX-9 last night. First drive to work today. I'm glad it has blind spot monitoring because I feel blind changing lanes. Still trying to get the mirrors adjusted but I'm pretty sure there will be a true blind spot even with the mirrors in the correct outward position. I'll pick up some of those little stick on spot mirrors.
The non-bose stereo is surprisingly well rounded. Its grainy like all cheap speakers but there are no ear wincing peaks like in Amanda's Focus. The sound stage is great and I can't wait to throw in some better speakers. I've already been chatting with Oleg about ideas.
Not sure what I'll do for rims. I think my old 18x8 Rotas will fit...but I think 20"s look better. The GT comes with 20s but I specifically didn't want 20" OEM Rims since I will likely use them for winter driving only.
I'm curious about finding the plug-in NAV unit for the factory radio. I don't use NAV often but on long trips it will be nice to have it integrated. We'll see. If I can get one cheap I'll drop it in. I've also been accustomed to having the auto dimming mirror. I'm guessing that can be installed after the fact, right?
Oh, then you're out of the club.
Will never happen.
Still waiting for it here.
Maybe, can you still listen to another source while doing that? We have an older Garmin, never messed around with BT, not even sure it has it.Does it have bluetooth audio? Couldn't you just use a smartphone nav and pipe it in through bluetooth?
I dunno, I like everything integrated...assuming it works. Like I said, if I could get the unit cheap I would install it but if it is too expensive I won't bother.
Also, I'm having iPod issues which are apparently common. It reads my iPod no problem, but every time I start the car it plays "Astral Projection" instead of resuming where I left off. A quick search and the problem exists on pretty much all 2012-2015 Mazdas. I'm going to try bluetooth. If that doesn't solve it, and Mazda doesn't offer a fix in the next 6 months, I may be pulling the entire unit and putting an aftermarket one in.
I just use my smart phone for nav for the times I need it.
If you are doing everything from one device yeah. If you are running nav and music off of your phone, the nav will just chime in when needed.Maybe, can you still listen to another source while doing that? We have an older Garmin, never messed around with BT, not even sure it has it.
