Feb 2014 meet
Indeed!
Did I miss anything exciting after I left?
Missed Marlon telling me that my car is as loud as Spicy. I disagree, but I've never heard the car outside with it moving.
That little Fiat seemed pretty flat through all the corners. I saw Dave couldn't keep the pace with you in the twisties. tee-hee.
We should set up a small spring fun run.
I'm down with that.
And yeah man, it does feel rather flat thru the turns. Gets a little roll but no more than the Miata has. It has some nice rotation to it too. Could be that 22mm rear bar.
Stock it has a 22mm rear sway bar? That's what's up. That was the biggest aftermarket size you could get for the Protege (Progress). haha
What size tires does it have?
I'm down for a fun run for sure!
Yessir, stock 22mm bar with a wheelbase slightly longer than a Miata. There are some upgrades available as seen in the picture. This is 25mm
It has 195/45-16's on it. Stock 17's are 205/40-17 (same as stock MSM). I just happen to have those relatively new RA-1's in my basement in 205/40-17...
