So, I guess we just need to wait for Corksport to come out with that 6-speed transmission... (headbang)
I looked in one of my speadsheets and if you look at the max speed in each gear, a car with the 4.4 and the DT tune with the higher limiter will be basically the same in each gear as the stock car. Down the road the 4.4 is tempting for me. I wonder if Joe can correct the speedo for the gearing change.
The speedo uses the abs sensors so there is no need for any correction.I wonder if Joe can correct the speedo for the gearing change.
So the B-spec cars do not run a LSD?
