rar40941's build thread
The ones I have last about a year until they rip what have u don Adam did u go with the AAC kit or u sticking with the latches ?
sorry I haven't posted in here for a while. I sold my old coilover and bought br and new bc br coilovers custom spring rates and 50 mm shorter springs and struts with custom Sprin rates at 11kg front and 16kg rear. I also got k sport rear camber plates to I can get more camber in the rear. I bought some bee radiator supports And New washer kit the engine bay. I am also getting my lips and barrels made for my new Wheels here are pics of my new wheels and all my new parts I need to install. I also got a new cluster pod so I can put some gages in.
I also sold my old wheels my new lips and barrels should be don in like a week or so I just need to get the faces powder coated and then I have to Put the wheels together. I am going to install all the things except my coils tonight and I will post pic. I will be installing my new coils on Saturday and I will be making a new YouTube video to up date. If u want more frequent up dates add my on Instagram or Facebook user name is RAR40941 on Instagram and on face book my name is Reg Rivera. So ya I will post more pics in a bit
The K-sport camber plates worked well for me and got me about -1.3 degree of camber. Just make sure you grind down the supplied allen bolts so they sit flush with the top of the spring.
Before:
After:
Just curious, why did you order those spring rates? That's pretty darn stiff in the rear, no? Might get a lot of oversteer with that setup.
I did those springs rates cause it's a mixture of track and stance track spec is 500 front and 850 this is 600 front and 900 rear so it's perfect for track and stance set up I just put my camber plates on did u Eve have a problem installing them cause the bolts aren't angled ? Like the bc top hats
I installed the plates today
i will install them tonight and I did a hoe.to on how to install the plates and Will do an install video
No offence to you rar but do you guys really think having the spring right up against that plate is okay?? Any camber and the spring is coming at that thing on an angle. it wont be able to sit flat, only a small area of the spring will actually be in contact with the bottom of that plate, which means it could move around. Pretty sketchy. Has no one else noticed you kinda need upper spring perches to make this set up work properly??
Agreed, never noticed that until now. Doesn't look right.
Those are supposed to be pillow ball upper mounts and with the spring right there it doesn't look like it can move.
Very interesting point gentlemen. I never really thought about it...
I never had any issues (that I'm aware of) with this setup on my P5 when I auto-x'ed it a handful of times and flogged it on the streets. But I've since sold the P5 and it's been on jackstands for about a year so I can't comment on how they've been holding up.
For reference in your How-To you're more than welcome to use these pics, Reg.
BC's and K-sport camber plates exploded view;
BC's exploded view;
