This bothers me so much. I see it on every major car blog, multiple typos in the feature.
Looking good though Reg!
Kinda wish we wrote the peace instead of them. All I got to say at least it's better then then last one
This plus bad grammar. Terrible.
It does too but just so much money to go fast
Never seen those pressed in rings on any of my wheels. They don't fit over the studs?
They almost look like reducers of some kind. Like you said if they were on a car with tiny studs they might have been put into the wheels to make everything fit better when you tighten the lug nuts. Is it possible to tap them out from the back? Maybe there is a more normal sized conical seat behind them.
The only thing I can think of at the moment is that VW might use a lug bolt that is more narrow than the studs that mazda uses. This would probably require some kind of seat/ring to be added into the wheel so the tapered lug bolt fits in correctly when things get tightened down. The only thing is that they look like they have been in there for some time.
If you want to get them out try putting a bolt that is larger than the hole on top and giving it a few love taps with a short handled 5 pound mallet. From the back side obviously. They should pop out pretty easy.
Ok the hole size isn't the problem.
Turns out the wheels are 5x112.
Thoughts on opening up the holes a little bit with a 5/8 bit and then using wobble lug nuts? Or should I just sell them?
