hahaha i see what you did there
quick question for guys(may be a dumb question but im going to ask anyways). when replacing the driver side axle, is it possible to do without removing the mid axle? is it possible to just remove the axle from the mid axle or do you have to remove all of it? ive went through a few different right ups and seen a few different ways and figued id just ask how any of you have done it
i think you have to remove the entire axle, but its not that much work. like 2 brackets, and then just rip on the son of a b****
EDIT: actaully thats the passenger side im thinking of i think. the drivers side should come out alone
I have an extra set of protege sedan fog lights i'm thinking about shoving a projector into:
If you've ever had to replace the bulb on the sedan fog lights, i feel bad for you. If you had no trouble replacing it, i hate you because the screws holding the cover over the light thing broke off inside both the lights that came with my car and just now both the lights i pulled off a newer millenia. I also broke the bolt that holds the mounding bracket and now it's partially stuck inside one of the millenia lamps.
I have no idea why sedan fog lights are cursed, but i need a projector that's around 2 inches in diameter and small/narrow enough to be somehow mounted on the fog light.
I'd rather mess up some already messed up fog lamps than my beautifully restored head lights:
Okay, so they're not as nice and clear as new ones... but it was cheaper eh?
Front motor mount switched, on to the rear.
Haven't got that far. Taking off the exhaust Mani and do to switch those back to stock also.
found out my rear camber is screwed up on my driver side rear wheel. thanks to Circuit found out i could use camber bolts in the rear to adjust it. new project to
do this weekend.
