So far all I can say is the night tech bulbs give off slightly whiter light than stock, and have some blue reflection in the housings. I'll post a functional review once I drive at night with them (may be awhile). I decided I'll be ordering the PIAA yellow bulbs for my fogs and the Phillips xtreme vision for the low beams in the 5. Not sure what I want to use for high beams in the 5 yet, its a separate bulb.
Night tech, that's the new bulb from PIAA right? I must say the stock housing is pretty good with a better bulb. I still want more lighting, and I may get a different bulb set up for winter. Yellow PIAA H4, H11 and xtreme white driving lamp hiding behind in the hole of the front license plate. I saw I could remove the bumper, remove the plate + cut the space behind it, remove some foam and make a bracket for the front crash bar. This way I could close the hole with the factory front plastic plate cover when I don't want to use them.... When I get the parts this fall I'll make this mod
