Perro del Sol
- 2003 MSP, Spicy Orange, 2004 Mazda 6 Hatch, 2004 Mazda 6 Wagon
installed JBR Rear Camber Arms and the Short Shifter Plate and Bushings, along with the JBR Shift Knob.
my head liner is impossible to maintain because i have had the windows open mostly.also....never knew how dirty this was till i hit it with a vacuum right quick
screen capture program
ha at least you are movingput in towplate
changed from a d07 to a d10 meth nozzle
changed from a 150psi pump to 300psi
go do pulls
stumbling because rich as **** from meth
forever slow
real quick before i watch ,keep foot floored and crank over for 30 seconds before starting
this will give the oil pump the chance to get oil up into the head, through the turbo bearings etc before everything starts spinning fast
thats what i did when my car was down for 3 months
http://www.youtube.com/watch?v=QH7WkRCrXM0
Ah ha . did not know that .Cranking with the gas floored locks out the fuel. Its a safety feature. You can do this to re pressurize the fuel rail after swapping hpfps or whatever. It prevents the injectors from firing
