The Ohio Random Thread... aka We Should Probably Be Working
Run slicks.
Problem solved.
Lol. Rubbing fender shouldn't be an issue. It's that bit of the chassis above the tire....
No slicks phen!
Pshaw...that's easy then. Notch that chassis with a dremel! Or save cutting wheels and have Phen bring his tool of choice over....the BFH!
http://www.awrracing.com/media/wide_body_instructions.pdf
*basic write up on flares, shows how much of the fenders you can remove for that brand (other brands vary but can still give you alot of room, and given your issue is on the frame, i would suggest spacing them out and going with flares then you wont have to worry about hitting frame and fenders are wider/larger and therefore (hopefully) dont rub either
BFH FTW!!!
I wish I could sell the Prism and get a decent amount for it then buy a MSP like that for a DD :(
Needs some appropriately sized tires for those wheels...
