Show me your CX-5 wheels
I am thinking about fitting 22x9 265/40/22 on my cx-5. I could use some thoughts and expertise, do you think this spec will have any problems with rubbing?
I have a set of 22x9 Verde parallax with tires I am trying to sell that I have on my CX-5. Only looking for $1500. They don't rub at all and the guy I buy all my tires from matched them with the CX-5 with offset.
Let's see some pictures!
Well, what's the offset? Rubbing is dependent on wheel width, wheel offset, tire wide and height in combination with the wheel diameter... Not just wheel width and diameter.
Best CX-5 to date.
TSW MAX A20x10x40 (ET40) Tires 275x40x20
There should be more than enough clearance given that you don't go too wide and tall of a tire. Factory 225/50-19 will fit fine on a 19x8 and you can even go 235. The wheel well allow enough space to clear the fenders and fender liners even on 19x8 +35.
This here is the factory 19x7 +55 (or +53, forgot) running on 225/50-19 and 20 MM spacers.
Another fitting question.
I was looking for 20's. Would it fit some 20X9.5 +40?
And which size of tires should I look for?
245-45 (my preference)
255-45
265-40
275-40
I don't want any rub. And I also already have some H&R lowering springs.
255-45
265-40
275-40
According to http://www.rimsntires.com/specs.jsp
When speedometer reads 60mph (96.6km/h) actual speed will be 59.8mph (96.3km/h): 0.3% slower.
Package will stick out 20 mm (0.8'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Been so bored waiting for delivery of my CX5 so have bought these on 20x9j rims with 245/45/20 wheels
Wow only taken four months
Is there somebody here installed a 20's on a FWD CX5 if yes, i would like to know how is the handling and is the power affected by big wheels? Thanks..
