Post pics of your Mazda5
Freshly washed, waxed, and racked with the OEM rack.
some pictures of my 5 just put my wheels on today and unfortunately can not lower as the wheels stick out too much
put the rubber lip on the front bumper
aaaaahhhhhhhh
aaaaahhhhhhhh
Dip is SICK!
Wheels are SICK!
But that set up does need a slam to go with it. Looks good but please slam it!
aaaaahhhhhhhh
Nicely done! Is the car dipped or wrapped? Can you shoot a pic of the door jambs? Very curious where it ends.
Those rims look like the Tenzo Shu4 I used to have. Cheap rims but look reaallly nice in motion. And as Davicho said, it needs to go lower.
Dip is SICK!
Wheels are SICK!
Thanks
The car is dipped and i have custom mixed the topcoat on the exterior and wheels with blue and lavender pearl.
I cant drop it the wheels stick out tooooooo much and i cant get a smaller tire size than 205/40/18
If i want to drop it i will have to run negative camber and dont know what parts i will need can anyone help for front and back.
the wheels are works vs 3 pc split rims
8.5 x 18 et 18 on the rear with 205/40/18
7.5 x 18 et 18 on the front with 205/40/18
Thanks
Don't get me wrong, Works are super nice! I'd love to own a set. However, you would be running a lot of negative camber in order to run those offsets. Do you have any pictures for clearance in the front? If I'm not mistaken 18x8.5 +32, 18x9.5 +32, and 18x9 +35 are the most aggressive fitments i've seen on the 5's so far. Keep in mind, their camber was about 1.5 - 2 in the front and about 3+ in the rear. It's possible, but goodbye to your tires! Would look good if you could pull it off.
Not sure how much shows; but they are black saturated metallic over chrome powdercoat. The sun really lights it up. Polished everything else and I need to finish making my center caps since Volks doesn't believe in making anything for their old style products.
