- Banned For Being A Troll
I have a T25 Flanged housing for a GT30 Turbo if anyone is interested in going "Bigger"
You will need to find a GT30, but they are common.
Oil leaks cuz of dirty air filter. Stock t25 is ball bearing. If you take it apart you'll break it, and you cannot get service parts anyways.
i can also post up all the parts i used to make mine convertable.
please do!
I'm going with a T25 as well. besides the 2 bolt inlet flange and 3 bolt outlet flange, will I also need new oil lines or adapters?
everything should bolt up, you will need a smaller oil restrictor though. you'll also need to clock the turbo
when I was trying to get my Tb2804 to fit, I had to trim the wastegate bracket and drill out the holes a little on it.
