I've been playing all day with the various component sites because I want to make a set that doesn't look like it was made by a plumber and finally stumbled upon these. Just kind of pricey, especially since shipping won't be cheap.
http://shop.k-sport-germany.com/index.php?a=48402&lang=eng
Here's where I'm at with the do it yourself options.
From MPC, there is a chrome plated option if you don't mind going SAE. However, the rectangular ball joints don't look as strong for an endlink application, but tough to say if it will handle our cars as they don't list any specs. As none of the endlinks I've seen ever use this kind of ball joint, I am leaning against this one, but it would look pretty.
http://www.midwestcontrol.com/part.php?id=32
There is a left hand thread version too, so you can get a matching LH/RH chrome rod, part# TRC375. What I don't like about that is they have 2.75" threads, meaning 2" of thread will be showing even when you go as short as possible.
I really don't want to put any zinc plated crap on the car, but in AZ, I am sure it will last literally forever. And in that case, the best options is this.
http://www.midwestcontrol.com/part.php?id=2880
Along with the left hand version, and then a hex tube from Misumi, part# LBMF10 (and you can specify any length you want). That should look pretty professional until the clear zinc gives way to the rust. With Misumi you have the option of black oxide, nickel plating, or stainless. None of them are prone to corrosion, and the cheapest is black, so that's the economical choice. Shiny is always nice though.
I really would like to use these. http://www.midwestcontrol.com/part.php?id=151
However, there is no left hand equivalent, meaning you have to find a RH/RH threaded stud long enough and you won't be able to adjust length without taking them off the car. I've found one on Amazon long enough for the rear, but no luck on the front.
Here's the Amazon link. https://www.amazon.com (commissions earned)
Considering that all the do it yourself options cost less together than the AWR order that I just canceled, I am tempted to just order then all and see which ones I like the best.
