Don't use a screwdriver. Use your grippy hands and pull hard straight out. I think so long as you don't turn your car on you can safely plug it in without disconnecting the battery. But if your worried just disconnect it.
Alright, I am done with the Navigation installation this morning. Once I took the Pocket assy out, it took only 10 mins to install the Nav unit. The toughest part for me was to take off the Pocket assy. Here is what I did.
1) Disconnected the negative terminal of the battery and wrapped the cable with a cloth (just to avoid it to contact any metal surface while hanging free).
2) I tried to use my bare hands to pull the pocket assy. Also tried to use a small flat head screw driver wrapped with a piece of cloth and pry open. Both times, I failed. Because, the pocket assy was tightly held by the panel. And I didnt have any grip to pull it out.
3) So, I looked underneath the small opening right beneath the hood-release-lever and used a flash light to see what is in there. I was able to see the pocket assy and the 3 cables (USB, +B/ACC and GPS antenna cables) that are connected to it. First I tried to push the pocket assy by inserting my hands through the opening in the lower panel. It was tough to push it because a) the assy was secured so tightly by the clips b) the cables were in the way so I couldn't get a good grip. So, I removed one of the cables (gps antenna cable) from the pocket assy and now I had a little bit more grip. Then I grasped the entire pocket assy's back and then pushed real hard. Voila, it f**ing popped right out giving the back of my hands a couple of scratches with some blood
. So, be careful while u push it out. THIS WAS THE HARDEST PART for me!!!
4) Now, I removed the other 2 cables (USB and +B/ACC) from the back of the assy.
5) I removed the Wiring harness clip. Now the pocket assy is free of any cables/wires. I put aside the pocket assy (wheww!!!).
6) Now, I took the Nav unit and connected all the 3 cables first and then connected the wiring harness clip.
7) I toyed around 2-3 times to align the Nav unit with the four clip holders on the panel. Then, pushed the upper 2 clips on the edges and then the lower 2 clips. The Nav unit snapped right in - perfect fit.
8) Used the flash light again and looked through the opening under the hood-release-lever and ensured if the Nav unit is in place with all the cables attached.
9) Connected the negative terminal of the battery.
10) Performed all the checks as mentioned in the instruction manual (turning ON the push button start, pressing the power/audio button, etc., etc.,)
11) Now, I disconnected the battery negative terminal again to reset (like it said in the instructions!).
12) Then, just followed the instructions to set the power windows, moonroof, TPMS etc., I had to set the time, set all the preset radio stations, my trip meter and avg. mpg were all reset bcoz of the battery disconnection!
13) I took a test drive by using the GPS and it was all GREAT!!! (rockon)
Thanks for everyone who responded for my questions...(2thumbs)
