NEX Coils
Lol after adjusted properly... I've been running them for like 8yrs (without dampening but) the ride is perfect for me. They were selling for the same as the ksports back then and didnt have the dampening adjustments or the complaints that came with them. Solid and will slam you to the ground and beyond if you want that!
coils thanks for the helps guys.. Shane do you know about how much camber you can get just on the coils alone.. without any helpers?
They have a slotted upper hub mount hole maybe 1.5deg. I slotted mine a hair further with a drill still on the car...
Hmm that's not a lot.. I've been told that d2's can get 3-3.5.. Is it still structurally sound after you did a little more yourself? Damn I hate being on a budget, bc if I wasn't I would get kw variants
why not spend a little bit more and get some yellowspeeds from CR3?
I thought about it but I don't know much about yellowspeeds? Are they a good dd coil, and what is max camber without helping elements... Are they available for custom spring rates later on for when it's not a dd?
I'd say they're better quality than this, more comparable to BCs. They have camber plates for the front and you can get custom spring rates.
Alright would I have to get like camber bolts or the rear lat link kit for the rear coils? Or is there a trick to get rear camber off of coils that don't offer it
