I was changing out the ATF in my car this weekend and inspected the motor mounts. The driver's side and passenger's side motor mounts look fine. The front motor mount rubber had a look of dry rot but was not fully torn. I couldn't get a good look at the rear motor mount. I ordered some Corksport motor mount inserts for the front and rear.
1. Should I get a new front motor mount if the rubber on the motor mount is worn or will the insert just hold up inside the old motor mount?
2. The instructions to replace the rear motor mount or to install inserts looks like a pain in the butt; that entails removing the strut tower bar, battery, throttle body intake tube, cutting a bolt sticking out of the firewall with a Dremel tool, removing three nuts from the motor mount-to-cross member bolts and then removing the motor mount-to-bracket bolt. While underneath the car, I saw this bracket with three bolts connected to the transmission and the top part of that bracket had one bolt going through the rear motor mount. It looks easier to keep the motor mount bolted to the cross member and then just remove the three bolts from the transmission bracket, the one bolt from the motor mount-to-bracket bolt from underneath, stick in the motor mount inserts and reinstall the bolts. Anyone else did it this way?
