mazda3 exhaust for cx5?
Mazda 6 iTouring 6MT
It seems like the platform is very similar for both the 3 and cx5 but does anyone know or think an exhaust made for the mazda3 would fit the cx5? I'm sure it would need some minor adjustments w the hangers but I think it's doable, any suggestions?
The CX-5 platform is from a clean sheet of paper. There may be some parts interchangability between it and the new 3 which comes out next year, but I doubt anything from the current model 3 would fit.
i know but from looking underneath the cx5 and 3 skyactive the exhaust path is almost identical so i believe it should work
may i ask why you want to do this?
its pretty straight forward. im asking about putting an exhaust on my cx5 because i want an aftermarket exhaust... on my cx 5
If you don't want to answer the question - just say so. Saying "I want it because I want it" doesn't add anything. I too am curious what you will gain by this?
Not sure it would work but...I believe corksport is in the design process for an exhaust system for the cx5.
yes they are it should be the same exhaust they made for the mazda3 2.0 just with a dual exhaust instead of a single but everytime I ask about it via fb I never get a response
aren't the 2.5L and the mazdaspeed3 dual outlets? i wonder if those bolt up nicely. just wondering. i'm happy with just some beefier tips.
Instead of buying an exhuast for another platform and modifying it to fit, why not just go custom. If all your after is sound, welding up a new muffler is all you really need to do. Find a shop that does that and have them quote you a price. It may be cheaper than a catback for a 3.
yeah i considered going custom and been looking into it for awhile now but it wasn't until recently when i looked under both vehicles and noticed the exhaust pattern was almost identical thats why i asked about the mazda3 exhaust fitting the cx5
yes they are but depending on the exhaust manufacturer the exhaust my or may not fit, for example corksport dual exhaust uses a different pattern then the stock exhaust and the way the cx5 is underneath the piping has to go directly in the center
Why does it matter why he wants to? That's his preference that he wants an exhaust on it. If my wife and I purchase one next year it will get an exhaust on it at some point too. I'd do it for the aggressive sound as well as the nice bump in mid range and top end power while allowing an extra MPG or two at cruising.
The CX-5 comes with an exhaust from the factory. So I'm not sure what you're saying. I was wondering what he hoped to gain with an exhaust made for a Mazda3.
LOL! Here we go again!
The exhaust systems on modern cars are not restrictive enough to reduce fuel economy. In fact, you will get lower fuel economy and worse throttle response if you change the back pressure characteristics and natural resonance frequencies of the stock exhaust without figuring how to correct the fueling. The engine is not designed to automatically adjust for a header or exhaust pipe with different characteristics - that's why your car will run worse, not better, after such a change. This is especially true in a car like the CX-5 which has a highly tuned header and exhaust system - all the operational thresholds and the tuning is designed for the characteristics of the system at various rpm's and throttle openings. Good luck finding anyone who knows how to make everything as good as it was with the standard exhaust.
I laugh at the "ricers" who pull away from the gas station with their new Honda (or insert make of your choice here) with the exhaust sounding louder and faster than a herd of wild buffaloes but the car going nowhere fast. More gutless than the stock car, many of them would have a hard time outrunning a herd of buffalo! But they have spent thousands of dollars absolutely ruining the throttle response and acceleration of their almost brand new car! Oh, and their fuel economy. They have wasted so much money that they can't even admit it to themselves that they made their car slower than ever. At least it sounds "cool" to their friends. I have to think these people have smaller than average penises. Or maybe just their brain.
But to answer your question, I was simply curious what he hoped to gain with an exhaust made for a Mazda 3. It's his car, I don't care if he wastes his money making it run worse. People do it all the time.
yeah, it is funny when they 'sound' like they are going fast and yet I'm making no attempt to go fast at all and I'm out ahead of them.
But I'm not even a fan of the big V8 cars that make a ton of racket when going slow. To me a car like that should sound mellow at slow speeds and then when you really stand on it wake everyone up.
funny read, shows how well you understand modern engines...
this is what CAN happen when you get a well designed aftermarket exhaust onto a modern engine design:
http://www.mazdatalkforum.com/viewtopic.php?f=10&t=2598&p=16207#p16207
granted, its not a civic, but it is a newer car.
but our cars already have a tuned header.
The dyno runs they had listed were all for complete exhausts, none with a header and stock exhaust compared to a header and aftermarket exhaust.
Funny read, "this is what CAN happen when you get a well designed aftermarket exhaust onto a modern engine design".
Note: CX-5 2.0L has a well-designed exhaust from the factory (as noted by ta240), just look at details on Skyactiv exhaust. Yep, it's no Civic.
my point was that you cannot generalize by saying 'your car will run worse with an aftermarket exhaust'. I'm sure even the CX5 would benefit from a less restrictive, properly sized, aftermarket exhaust and intake. i know the Skyactive header was designed VERY well for a stock piece, but that doesn't mean there is NO room for improvement in the system. a good engineer knows that compromises need to be made when bringing a product to market. if mazda went with the no compromise - full performance design, no one would be able to afford the car.
I do see your point, but this is about the Skyactiv 2.0L CX-5 exhaust, not some soon to be riced-out Civic. So speaking of generalizations "I'm sure even the CX5 would benefit from a less restrictive, properly sized, aftermarket exhaust and intake.", that sounds great in theory, but nothing supports the generalization. A good engineer at some garage operation doesn't have the engineering resources of Mazda.
And if we make our CX-5 into a "full performance design" we would give up fuel economy, comfort, driveabilty, low end torque, reasonable sound levels, etc. Nobody would want the car (being a compact SUV) even if they could afford it.
Similar Threads and Articles
