Nope, love my Auto...haha...
Wanted to get a MT when I was buying but my wife also needed to drive....so ended up with the AT....been driving MT in my early teens and wanted the MT on the P5 (also cheaper than an AT) but after having the car since 2001....I'm use to it now. I do miss shifting thru the gears when I'm driving once in awhile. ;)
removed the black paint off my needles and im not able to see things at night
changed windshield wipers, cleaned the spray nozzles, fixed both brake light bulbs who were broken (I was driving with only the center hatch brake light working haha)
Reinstalled my hella supertones that have been PC'ed to match 22V by Signature Sound.
Paid for a Pacemaker Header straight out of Australia and will most likely be picking up Evo 9 Recaros tomorrow morning. :)
Well, my water pump went out. I'd thought for a while that it was going bad, but it completely took a dump on me, leaking coolant out through the shaft very quickly. Got it back home, where I have all the parts for a timing belt change including the new pump. With work and everything, she should be fixed up by the end of next week.
At least you were prepared with everything that is needed.
Bypassed the coolant lines for the throttle body. Patched it with turbo coolant lines. Replaced the brake booster line with a silicone hose. Put a one way check valve on it and T'd it off to my vacuum block. Used the intake manifold vacuum source and dedicated it to my blowoff valve.
Sounds like I may have sold mine. After almost 6 years, it's leaving. Served its purpose in many ways. Thank God it was a cheap purchase for such a disposable purpose.
