just buy a pinch weld adapter, worth the investment .
What about the dimpled area under the engine, it looks like a jack lift area?
The frame rails underneath the middle of the car and the control arms are the safest bets in my opinion. I do recall a place that sold adaptors for jack stands that can fit into the pinch welds. Forgot the name of the site but a Google search should yield results.
But I have had my CX-5 up in he air several times and I haven't had a problem damaging the pinches by dropping the car down on stands and resting the photographed jack zone on the stand pedestals. So meh...take it for it is worth.
whoa now, Ive had 4 miatas and built one into a racecar and Miatas are very different from typical unibody cars. You can jack up a miata from any point along the bottom. You cant do that to most other cars, you will bend sheetmetal.Years of working on my wife's Miata have shown me that there's really no more strength in the designated jacking portion of the pinchweld than anywhere else on it. I usually just jack the car up at the jack point and then place a jack stand right next to it on the pinchweld.
How is an MX-5 pinchweld any different from a CX-5 pinchweld or a pinchweld on any other car (Mazda?) for that matter?whoa now, Ive had 4 miatas and built one into a racecar and Miatas are very different from typical unibody cars. You can jack up a miata from any point along the bottom. You cant do that to most other cars, you will bend sheetmetal.
Good god man, isn't that the rear diff? If you try to jack your car up there it could be a VERY expensive mistake.
Seriously, the manual CLEARLY shows on page 7-9 that the jack point is at the OUTSIDE of the car near the rear tire, NOT in the middle.
[EDIT] It looks like there is a household door in the background of your photo? The proper jack point looks like it is way out where the car outline meets that door.
