jimmysuite
 - 2003 Mazda Protege5
have people been posting dynos?...
Also did you ever start the "second" build?
Nope probably not ever going to happen either.
Hard reading all these ancient threads finding info. Is there anyone here left that has any N/A stuff left for sale? Or know where to get some?
I guess I am looking for the JDM ecu for a fs-ze motor along with the crank trigger.. As of now I have the JDM intake and exhaust cams from like 10 years ago, OBX header, OBD I harness, 10.4:1 pistons, ported and polished intake with VCTS delete. (and a tone of other stuff that's not important now).
I see some wiffs of information on a few people running the mp3 ecu on the FS-ZE motor with luck, but I can't believe that it makes any more power with the ecu not taking advantage of the parts. If someone actually has dyno proof that just with the mps ecu and higher compression along with cams makes more power than that's a root I would consider.
Or another forum where these guys went so I can know what to get. Otherwise I am done. I am stuck behind a RX7 and a BMW 325i, and racing this station wagon is getting boring. I will just save my money and buy a van deimon.
honestly that NA 'station wagon' is never going to compete with the cars you mentioned...certainly not in a straight line. If it is supreme speed you want then you unfortunately have to go turbo... Even a pretty extreme 200hp FS is not going to be earth shatteringly fast.. It'll be quick, and awesome in its own way, but if it is outright performance you want then this isn't the way to do it (making 200hp+ with a turbo build would cost you less).
This thread really wont help you much with the JDM ecu question. To do the kinds of things that were talked about in here with the FS you are almost certainly in the realms of a stand alone - if for no other reason then to get the revs you need to pull it off.
It was fun while it lasted, but several of us have given up... life gets in the way of fun toys and silly back yard engineering projects...
An mp3 ecu would be the only stock offering that would mildly take advantage of higher compression...the stock ecu definitely won't, its ignition maps are a joke for an engine with such little dwell time...the mp3 ignition timing, on the other hand, will advance quite a bit with the right gas...and you need the ignition advance to make up for piston heads being 'higher' in the cylinders.
the mp3 ecu should work fine with the mild jdm cams and pistons, its just the sensors i'm not sure about.
Damn dude... I am so glad I have spent a ton of time on here reading all the N/A threads for the past few weeks. Because that all makes sense. (bowdown) I will get the deeper spark plugs to grab back some timing from the taller pistons. And so with the two different heat ranges. Thank you so much!!!!! Seriously that is some great info! I can't believe this info is so hard to come by. It's nice to see a P5 so high up on the small prod list! I just want to be #1
But again with more questions...... The HC pistons are .050 over. In this motor do I need to get the motor board over to accommodate? Also with both (the stock and HC) pistons fully assembled with pins and rings, and (lets say) they weigh the same. Will I still have to get the bottom balanced?
Also should I make a "build thread"?
OK I will start a build thread the moment I start tearing the motor down. However, do I need to sent the bottom end out????Damn dude... I am so glad I have spent a ton of time on here reading all the N/A threads for the past few weeks. Because that all makes sense. (bowdown) I will get the deeper spark plugs to grab back some timing from the taller pistons. And so with the two different heat ranges. Thank you so much!!!!! Seriously that is some great info! I can't believe this info is so hard to come by. It's nice to see a P5 so high up on the small prod list! I just want to be #1
Pre-requisite of a build thread is for everyone to post and post and post before anything is actually done.
