2nd Msp Build
Ordering the n2k sag fix finishing the port and polish on the intake Manifold and repairing the exhaust pipe so i can dyno the car before the install of p&p intake mani and gonna check the car for any vacumms leaks or anything that could affect the dyno number planning on getting an aftermarket bov to help with no leaks also ordering the outlaw engineering thermo spacer kit with coolant bypass
Got this awr header flange today for an awesome price gonna be making a custom piece soon
Very nice. I need one if those flanges for the new t3 twin scroll setup I plan to run. Can't wait to see what you do with it.
truthfully ill be selling the msp after i finish the intake mani only to get what ive been wanting which is the p5 whole reason behind the paint job was to up the value....
plans so far i have a intake mani leak the fix will be the port and polish with all new gaskets with the vcts and butterfly delete and block of the coolant line to the throttle body, i would like an oem fuel pump cuz i think walbro is supplying to much fuel making me run rich and fix the dent i put into my exhaust piping including the leaks that ive acquired, just need to order the anti sag fix kit and one headlight since one start to crack to put it up for sale
Parts for the P5
Header flange from awr LONG TUBE HEADER ends at 2.75 that will be mated to a 2.75 catless exhaust under axle exhaust build will start soon
Keeping the Nology Wires for the P5
Eaton M62 Clutched supercharger (buying on friday)
Also buying MALESKIMP3 thermal spacer kit (Buying it friday)
just found this build, great car love the titanium's hope whoever buys it continues the good work.
Got some work on the mani need to buy some bits been lagging cuz of skool but i order the thermal spacer kit from the group buy more motivation to finish
Got these 350z rays engineering 350z Track R V.1 wheels
18x8 30 offset
18x8.5 33 offset
18 lbs a rims
plans so far maybe run the 8.5 in the front with a 215/40 or 225/40 no spacer need for center hub and in the back 18x8 with a spacer to make up for the center hub with a 215/40 or 225/40
