Yeah, probably toss another motor in and sell the ****** and get an MS3
Sounds like good advice from 20t03speed is offering you some good advice and lower the boost! Knowing these motors have limitations, why push it? If you want a Speed 3 trade it in now and move on.
These motors have limitations!?!?! I'm well aware of the "limitations"... I have a pile of parts/blocks out in my shop right now... lol
If I had an extra engine, I'd totally build it, but after grenading my back up, then another engine I'm fresh out.
I'm totally thinking about getting a Water-Methanol kit- Snow stage II... Anyone other than Joey using Water/Methanol injection?
yea i used adobe illustrator, i use it every day @ work (graphic design/IT/network admin)
in other news: received my double din yesterday! just gotta wait on the surround thing to get here to install it
Mishimoto Radiator installed, have to re-route my cold pipe after removing the the OEM Radiator because the old piping would not allow the radiator to fit. So a new elbow is going on the FMIC and then we will do a mandrel bend to get pipe back to the throttle body, as I don't link have all those couplers on the piping. Should have it done by today.....
Exciting!!!!!!!
She is done and I will have her back when I get off work......All I have to do next is get the AWR rear sway on Saturday and have the Hooisers mounted on the RPF-1's....
P.E.P. downpipe just arrived at my front door!!! super excited... even though my car still isn't working..lol
[/IMG]
Where did you order that from? how much do those go for ?
So after getting rid of the P0171, now im getting an exhaust leak code, it must be a small leak, ill clear it and then it comes back on after 40 miles ... im thinking one; it couyld be from when i had my SLS mid-pipe put in, they didnt use a gasket they used exhaust adheasive instead ... what is the correct gasket that conects to the mid-pipe to the rest of the exhaust ? im guessing they used that other stuf because i didnt get the correct one ...? any thoughts?
An "exhaust leak code" doesn't exist...
That is a Pope downpipe, no longer in production. Just had a final run of 25 units and they're done. There may be another vendor taking over production, but that's not definite yet.
