jumaaneface
- 2003 mazdaspeed protege black mica
Just recently purchased a 2003 mazdaspeed protg sitting at 117k miles.
Past week for so I have been having issues with low idle. When car idles rpms will dip and stay steady at 200-400rpm. Same takes place when moving and shifting into neutral. Has yet to stall at any point during any of this so I'm taking that as a possible good sign?
Second issue is when doing a hard pull, occasionally she. Shifting from 2nd to 3rd I can hear it Backfire from the exhaust.
Third and final issue would be boost spiking up to ~10psi
When under hard acceleration.
Looking around the forum I've seen numerous people with similar issues.
If my car is indeed over boosting the wga should be replaced? Or is there something else that could be wrong.
With the low idle issue I have so far replaced the plugs in an attempt to correct it but that did not solve the issue. I purchased the NGK iridium stock heat range plugs but did not regapp them. Could this be a source of the issue? Plugs I took out were also at a gap of about .044~
Any info would be overwhelmingly helpful.
Current mods that I'm aware of would be aftermarket exhaust (unaware of the brand name) and CAI
