figured you would.
I'd have it ported and rebuilt with an upgraded compressor wheel...
Ivan, is your year the model with the bad turbos? Can you swap it out with an OEM revised one? Of course, I'd say go big or go home as well. But you're probably not allowed to soooo... (whistle)
It is not. I have one of the revised turbos. They all end up going at some point. Brand new is minimum 500 bucks if you can find a good deal. At this point I will buy Jake's for $100 and hope that it runs well until next year. At that point I will upgrade to something like the BNR and Cobb AP.
Ps- if anyone wants to come over and hang out, BS and lend a hand with pulling the motor, let me know. I'll ask Tessa to make a yummy dinner as a thank you.
Doesn't Mazda have a longer warranty on the turbos since every one of them was going bad?
i wouldnt upgrade the internals on a k04, i know a couple of ms3 guys that popped motors doing that... and they were tuned
sorry to hear the turbo is going Ivan, good luck replacing it. Do you have one already? if not ill keep my eyes open on forums for ya
Everything is ready for you.I can't believe my turbo has takin a s*** yet (knock on my hollow head) 125k on a stock MSP GT25 woohoo! Hopefully I can grap those parts from Nate thiss weekend and get the motor the following weekend from Evan and let the fun begin. Question is how do you break in a motor with 200k+ on it and boost it. I think either way it will pop within a couple events, but how long should I take it easy on it before I take it to an event? I can't wait to take mine in and have it bored over and let the fun begin.
Why do you need to break in a motor that's already running, silly pants? It hasn't been sitting or anything. Like Thomas said, maybe run some thicker oil and run it while you're building your motor. Honestly, I'll be a little sad when it pops because for an FS-DE to have almost a quarter million miles is an achievement from the previous owner, and all on the same clutch! Haha. I'm looking forward to pulling it and sending it over to you though.
I'm at 70,300 on stock turbo but a I looked at it while taking off the lower tie bar and looks like there might be some oil leaking![]()
I just didn't know about adding boost to it, but I really didn't think it would matter because either way the turbo is going to but it under more work no matter what and it isn't like I can just boost to 3psi then let off evey time. What day do you plan on pulling that out again? If I'm off I'll come over and lend a hand. I didn't know if you had a 32mm axle socket nut or a tie rod end spreader.
Hey Nate, I wanted to get those springs from you at the cookout so if you can fit them into your car as well that would be awesome.
I have those in the trunk already for you.
