Making a tooling gelcoat fiberglass reinforced mold for protege rear hatch
Removed all objects to make a smooth surface, except wiper since I'm not glassing the entire way across the glass since it will be cut off for lexan insert anyways.
Taped over all the holes with my trusty blue painters tape.
Last time I used 5 coats of liquid car polishing wax for my hood, this time I got some nice wax made specifically for mold making. Only need to do 1 layer of this stuff, goes on nice and thick.
"most" fiberglassers use spray guns for their mold release and the gelcoat...I don't have any of that fancy stuff so I did it the old fashioned way....a brush. I put down 2 coats of PVA mold release. Wait a half hour and it looks like a clear coat on top of the wax layer.
I used an orange tooling gel coat, I measured the surface area I would need, then did the math to figure out the weight I would need for the gelcoat...I used my electronic scale to measure the amount down to the gram until I had the exact number. Then I measured precisely 1.8% of the gel coat by weight in hardener and mixed it in.
STIR IT REALLLLLLLLLLLY WELL!!!
I put down basicly 2 coats of gelcoat, 1 thick and a lighter one to make sure I didn't miss any spots since....I'm using a brush, which I've never seen anyone else use before for gel coating.
I used 3M something 90 spray adhesive and plastered foil over the glass so the fiberglass didn't stick to it, since I didn't trust the wax on it.
I forgot I had short sleeves on after I'd done my first 2 layers of glass over the mold. I have hundreds of angry red sores on my arms now. I used duct tape to wrap my arms and yank most of the splinters out.
Afterwards I reccomend taking a shower as hot as you can stand it...and then as cold as it will go for a minute...its some kind of a trick to make you forget how much it hurts...but it seems to do the trick, I've had some fiberglassers from airplane companys give me that tip. Works well.
But....please....wear a long sleeve....it hurts.....
A LOT
I did up 3 layers of the last of my bad bondo glass with the last of my bad resin. I even used a can of resin that must have been 15 years old or more (the really bizarre green resin on the last layer)... I glassed in ABS plastic strips for some more support...yea...looks bad but remember that's the back and its just mold reinforcing. First 2 layers went on wickedly tight, had trouble getting the third one to get close with the longer ABS strips flexing. (its really hard doing this with only 2 hands)
I'll split it off the hatch tomorrow and then the real work can begin. The tooling gelcoats supposedly last the longest so I could make more copies if needed.
tomorrow breaking open my 5 gallon tub of nicer resin and the good glass, very exciting!
Cheers!
