What have you done to your Mazda5 today?
Rice mods: Got the caliper rust ground away and painted red and installed the shorty antenna.
HIDs arrived and waiting to go in once I get the relays delivered.
Also working out which wires to cut and tap based on the HID DRL instructions posted here: http://www.fordfusionclub.com/index.php?topic=86736.60
This past Friday:
Alignment (again): -1.4 camber, 0.0 toe front; -1.6 camber, 0.02 toe rear
Tires: 235/45-17 Sumitomo HTS A/S P01 (no rub, no fender roll) <-- these feel great! Cheap too.
Found out that NC MX-5 wheels (17x7 +55) only weigh 17 pounds. Score!
Found out that 09 MZ5 wheels (17x6.5 +52.5) weigh a whopping 21 pounds. Ouch!
Which means that my larger heavier tire on the lighter wheel still weighs 3 pounds less than the stock 205/50-17 setup.
Rearranged the spacers on the car- the 8mm are now in front so the 235 clears the BC coilover body with room to spare- which means that the top edge of the tire is JUST barely flush with the fender with the -1.4 degrees of camber. No more spacers in the rear since the rear lip is HUGE (17mm deep). Even the 5mm spacer (really 4.5mm) causes the 235 tire to rub the fender- still have tons of clearance past the inner edge of the tire though.
mounted the ebay wing and oem side skirts
all the items where spray painted with clear using rustoleum acrylic lacquer and cut and buffed with meguiars ultimate compound
I'm looking for a rear spoiler but the only ones I see on eBay are the BasonR VIP style spoiler, and I wanted something more understated. Which seller did you buy yours from?
I can't find the eBay wing anymore... wanted to order it so I could have it painted at the body shop while they're fixing collision damage. :(
State inspection and trans fluid changed. Significant difference in driving (good difference) after the change.
fog ballast went out so ditched the 6k's and put on 3k's with a new ballast location on the drivers side to eliminate the moisture that killed the first one!
My back-ordered rims and tires finally arrived. Installed them after we put the kids to bed.
Never mind. Looked at the WHOLE price now, saw only the unit price without shipping before. No way.
LOL! This is why I jumped on it when the seller was out of the US, ships out of Texas too! That Chinese seller was brought up before by the first guy who had this spoiler (also bought from eBay way back so this item comes and goes). Not sure when (if ever) I will get to mount it. I am sitting on a lot of stuff but just don't have the time/desire to do mods anymore.
Oh, the previous seller was in Texas? Damn, might as well waltz up to his place and just pick one up...
Got a ROLA roof rack for a deal due to damaged packaging. One of the cross bars had a ding in it, but it was pretty minor. Installed this week. Looks good and seems to sit lower than OEM rack - which is fine since I don't have a sunroof.
Installed better than stock speakers (nothing fancy) and started installing sound damping - a little at a time.
