The Slammed Life
Took first place Infiniti at the Ocean City Car and Truck show
my STi to the right :)
You really need to layer some primer in there to be able to see it blend... and show light reflection where it needs more work with more bondo... then sand then... more primer...
That was a mad fun weekend haha! Good seeing you at Seacret's too. I was pretty blasted.
[video]https://www.facebook.com/photo.php?v=4223529073251[/video]
a lot more bondo and shaping. I've done it before. Be careful with cracking the fender =P. bondo is sensitive to heat and will crack under pressure.
No more flares Edgar?
My rears look like that right now but much much worse. One of mine cracked in the center while my buddy was pulling it with his roller. He welded it then ground it down flat and sprayed the flares in flat black. They were abused as s*** by my wheels. I'll have some changes coming up soon. I installed BCs in the rear on Sunday so I have stiffer struts and about 1/4" more low in the rear. I could drop the whole car about 1 1/2" but it won't move then.
My fenders are ****** too u should get the fender ****** sticker lol
I have this on my front driver's side fender.
But I am not all about rocking a POS car with stickers that make it look worse so I do believe I have some fender flares in my future. I ordered some that should work pretty well. Hopefully they won't require any fiberglass work or modification. I plan on having the fenders radius-ed under the flares too.
