(idhitit)
Do we need to set up a separate stalker poast?
(idhitit)
Went to change my oil and rotate my tires a few minutes ago and discovered that my lower control arm had gobs of a grease type substance that may have a green tint (it was so dirty it was hard to tell). It was also all over the tie rod and the splash shield. I would say that if I had balled it all up it would be about the size of a baseball.
Anyone know what this is and where it is coming from? I should've gotten a picture but I didn't think about it until I had cleaned it all away and didn't readily see the source of it.
I also discovered that the top of my right side sway bar end link wasn't hooked up in the front and the nut is gone. So if anyone knows what size nut it takes that would be helpful as well.
Edit: Found a nut that fit the sway bar end link. Also, the mystery substance is also splattered on the inside of the wheel. And, not sure if this is related or not but there has been a slight squeaking coming from that corner.
Ugh sounds like a PITA aka something that I will not be doing myself. I'll take the wheel off tomorrow and check it out. Thanks guys for at least giving me something to look for.
Methinks your loose sway bar bits might have sliced something open perhaps.
drivetrain and suspension stuff can be tough, but doable with the right tools. i am just wondering if the whole halfshaft has to be replaced. essentially the cv joint is a sealed unit, so "quick fixes" arent a real good option
and honestly id rather replace the whole thing myself instead of repacking with grease and making an attempt to fix the boot
Yeah I think I remember seeing that somewhere too, maybe MSF? I might call the dealership just to see what craziness they spout.
I just checked Mazda Motorsports and they have a "REMAN, CV AXLE" part number: GG27-25-500R-0L for $179.18, which sounds to me what I would need.
I still need to verify that this is in fact what is wrong, but just from reading other people's experience around the internet I'm 90% positive because the symptoms are all the same.
Record the conversation and post it... it'll be good comedy.
Filled today from just under 1/2 a tank - 23.3 mpg, so that's almost 3 mpg better. I'm kinda surprised there was that much difference. With the recent fuel price declines, my fuel cost/mile went from $.20 to $.15All that is what I'm thinnin'. Doubt if I can get 26 mpg. I think 24 mpg is 'bout the best I can expect. So, I could expect to save around $.50/day. I drive it four days a week - that's $2.00/wk,. $8/month. Dang! In 2,000 years, I could retire!
