the Stance Thread v2.0
719, i think i might get the front plate tilt mount. its so silly i kind of like it
im wondering what tires i will need to fit some 17x8.25 rims....want a mild stretch as ill be on coils with these rims thanks
Best side profile I have without taking more: 17x8 with a 205/40r17 (8.58" width) Nitto Neogens. I know its not a 8.25" but its close. This is a common wheel/tire setup, there will be others. Beauty of it is that its not really stretch! 8" is still within Nitto's safe mounting widths, 8.25" ain't though
So what should I go with to keep an 8.25" size rim safe on mounting specs?
bthai:5954413 said:
Ineedmoarlow, i knew you were gonna murder a beautiful car. great job there!
Thanks for the bill of confidence my friend its a work in progress, doing body work and painting it this summer/fall
You will be fine. Stock MSP wheels are 17x7 +55 so the 17x8.25 +35 give you 4mm more inside clearance.
yup you should be ok man, it sounds like you dont want to stretch much so im assuming your not going to go as low as possible either. you will need a fender roll though.
I'm going all around 2.5" front right now is at 2".... Let's just say I'm not going extremely low right now bc it's my daily, but once I get another daily it's going low.... And ya I'm having EPwerks here in Indy do a roll n pull so they won't have to redo it later
